saff boost issue
Old Mar 13, 2017 | 12:41 PM
fozzy70's Avatar
fozzy70
Default saff boost issue
Hi all,
Having a boost issue on my 2wd staff.
Have recently gone back to stage 1. Have tried to reduce the boost to 15psi but it just keeps boosting until I release throttle. The actuator is loose and just drops over the wastegate lever.
Any advice to point me in the right direction would be greatly appreciated.
Cheers Steve
Old Mar 13, 2017 | 02:42 PM
Ridgey's Avatar
Ridgey
If the spring rate in the actuator is 15psi then that will be the minimum boost, e.g. -34, you may need to replace actuator or the spring in it, dependant upon actuator type you have .
Old Mar 13, 2017 | 02:48 PM
fozzy70's Avatar
fozzy70
To be honest I did wonder about the actuator, but thought it may be amal valve. I have a forge actuator that u bought second hand so not sure of spring rate. I know forge do a spring kit so will have a look tonight.
many thanks for your reply,much appreciated 👍🍻🍻
steve
Old Mar 13, 2017 | 03:39 PM
costina's Avatar
costina
Live long and prosper!!
The amal might be jetted to give more boost.
Link the actuator pipe to comp housing to bypas the amal and try.
Old Mar 13, 2017 | 03:58 PM
fozzy70's Avatar
fozzy70
The amal has been jetted, but surely I could just adjust actuator to reduce boost if the spring wasn't too strong?
Old Mar 13, 2017 | 06:27 PM
Ridgey's Avatar
Ridgey
If you bypass the amal like costina suggested, you would get an idea of the base boost pressure of your actuator.
Old Mar 13, 2017 | 06:47 PM
fozzy70's Avatar
fozzy70
Oh right, know what you mean now. many thanks for the help. I probably wont get a chance till Wednesday evening now, but will bypass the amal and see what happens. I had a -31 with stage one years ago, then went to dark greens with same actuator and 21psi. I only bought the forge because it was cheap and looked better,lol. Are the forge ones any good?
Steve
Old Mar 14, 2017 | 12:52 PM
Ridgey's Avatar
Ridgey
Dunno to be honest.
Good luck.
Old Mar 14, 2017 | 01:02 PM
fozzy70's Avatar
fozzy70
Cheers 👍,
will let you know how I get on tomorrow evening. Oh BTW, can you still get hold of amal valve restrictors from anywhere?
Old Mar 15, 2017 | 08:53 PM
fozzy70's Avatar
fozzy70
Sorted!
Cheers for the advice fellas, spot on. Got a forge spring kit this morning, changed the spring in the actuator for the yellow one and took for a drive. boosted straight to 16psi ish. quick adjustment and now its 14psi. Well pleased. Many thanks
Steve
Old Mar 17, 2017 | 06:36 PM
Ridgey's Avatar
Ridgey
Great when its a simple solution.
Old Mar 18, 2017 | 08:28 AM
fozzy70's Avatar
fozzy70
You're not wrong. I've lost count of amount of times something which should of been simple wasn't lol.
