Turbo Damper Bracket For 4x4 Head
Old Mar 8, 2017 | 12:02 PM
Craig J's Avatar
Craig J
Default Turbo Damper Bracket For 4x4 Head
Hello
Does anyone know of a solution or supplier (other than Spec-R) which allows you to use the original turbo damper with a 2wd manifold and 4x4 head? Pete at Spec R doesn't do his adaptor bracket anymore and I don't want to risk the hanger type as they are do not work as a vibration damper which could lead to vibration issues.
Craig
Old Mar 8, 2017 | 12:25 PM
costina's Avatar
costina
Live long and prosper!!
I am sure Anembo engineering can sort one for you.
Old Mar 8, 2017 | 01:11 PM
Sierrasideways's Avatar
Sierrasideways
Took me ages to find one 2nd hand. Hopefully Anembo can sort you out.
Philip.
Old Mar 8, 2017 | 06:21 PM
Craig J's Avatar
Craig J
Thanks for the help guys. I doubt Greig at Anembo would be able to turn it round in the timeframe I need so may need to go for a dodgy hanger temporarily.
Old Mar 8, 2017 | 06:27 PM
Sierrasideways
http://www.randbmotorsport.co.uk/sho...?ProductID=180
Chance him maybe?
