quick map sensor question
Old Apr 10, 2005 | 12:36 PM
stesrst's Avatar
stesrst
Default quick map sensor question
went to my 2wd cossie this mornin and it wouldnt run to cut a long story short i found the pipe to the map sensor split, i replaced it with the blue silicone stuff you get with a dump valve and it ticks over fine now,question is will this pipe be ok under load it wont get crushed or sucked in will it?
Old Apr 10, 2005 | 05:34 PM
foreigneRS's Avatar
foreigneRS
Testing the future
well it will see the same pressure as it would if used on a d/v, so if it's suitable for that, then it's suitable for MAP sensor connection.
if you really are concerned, you can check it by comparing the pressure on an analogue boost gauge with that sensed by the MAP sensor using a multimeter, but if there is going to be a problem with it collapsing or bursting, it will quickly show by running like a bag of shite (warning - continuing to run with this condition could cause engine damage)
Old Apr 10, 2005 | 05:40 PM
stesrst's Avatar
stesrst
cheers dude, its running ok just wanted to double check.
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Kam B
Sep 24, 2015 10:40 AM
Bransby
Sep 11, 2015 01:09 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
