brake pressure reduceing valve leaking saff 2wd
mines looked like it was hanging for years rusty as fuk but ok. cleaned it up painted it now its f...ing leaking. anyone taken theres of yet i no several they say it makes hardly any fifference. they recon if you left foot brake at 120 the back thinks about skipping a bit. i aint paying 100/200 for a second hand one. so fuk it its comeing of. if the back dont lock up its staying of
Just brake with the right foot,you should be ok.
Failing that look for a later abs equipped sierra as they are under the servo in the engine bay and usually in good condition and should not have cosworth tax on them.
Or you could weld up the leaking weep hole,heard of that being done before.
