S2 oil return size
Feb 14, 2017 | 06:56 PM
S2 oil return size
Can anyone tell me what size the turbo oil return pipe on the block (the tail that sticks out the block)
cheers
Feb 14, 2017 | 08:39 PM
Can let you know tomorrow if you don't find out before, I can measure the internal diameter of a return hose.
Feb 14, 2017 | 09:26 PM
Ok
cheers that would be good, it's so I can turn some alloy for my st170 engine conversion.
Feb 15, 2017 | 06:16 AM
If your using a rs turbo t3 it's the same size as the outlet pipe on the turbo, I will measure at work on a bit.
Feb 15, 2017 | 07:17 AM
Feb 15, 2017 | 09:21 AM
The hose internal diameter is 18mm that's a genuine ford hose. Hope that helps.
Feb 15, 2017 | 09:38 AM
thaks mate, what turbo are you running?
Feb 15, 2017 | 10:04 AM
Cossie spec T3 but I don't use the original ford oil return hose.
Feb 19, 2017 | 09:59 PM
Feb 21, 2017 | 09:29 AM
