Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
does the whole EGR + Manifold need to be removed to tighten a turbo oil feed bolt ?
Old Jan 28, 2017 | 12:19 PM
FastLife91's Avatar
FastLife91
Default does the whole EGR + Manifold need to be removed to tighten a turbo oil feed bolt ?
My car, 2006 ford focus sport 1.8 TDCI ( mk2 series)
It has a leak from top engine oil feed pipe bolt located at the rear of the engine near manifold e.t..c, It was loose so I tried to tighten it but could only get it finger tight, oil comes out of it with engine on. I cannot get space to turn because there is a box thing there (torque something I think someone said??)
how am I supposed to tighten the bolt fully without removing whole EGR and the manifold that it is integral with ?
it turns a bit but then stops and requires a spanner to tighten it but have no room at all, been at this for over 10 hours and still no luck so far.
please help
Old Jan 28, 2017 | 12:34 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I start cutting and welding spanners when I get to that point
Old Jan 28, 2017 | 12:46 PM
FastLife91's Avatar
FastLife91
I appreciate your fast response, thank you.
This is crazy, I actually considered that this morning but wasn't sure how to go about it and wasn't sure if it was possible.
How does one go about altering/cutting a spanner please ? if I can get the sides thinner I should be able to get a good turn.
I have tried looking for smaller width spanners but can't seem to find any.
please reply as soon as you are able.
thanks you very much
