Im in middle of fitting a stack dash into my clocks, and i only need the standard dash bulbs at top of clocks to work, handbrake, full beam etc etc,, so can i cut the bottom of the 'circuit board'? off? Below where the multi plugs connect?? It gets in the way of where stack loom plugs in,
cheers
