Mystery part
Old Jan 26, 2017 | 03:19 PM
BMrider's Avatar
BMrider
Default Mystery part
Whats this bit please?
1989 2.0 DOHC Sierra Sapphire with A/C manual trans.
Whats the objects in photo please, & what do they do?, cant see it in my manual?
has a vac supply from engine which causing a air leak
Thanks
sierra part by Mark Handley, on Flickr
Old Jan 26, 2017 | 03:57 PM
Caddyshack's Avatar
Caddyshack
I think it is a carbon filter - possibly early emissions stuff?
Old Jan 26, 2017 | 04:15 PM
BMrider's Avatar
BMrider
Cheers, but not sure it is, Carbon canister fitted to those vehicles with a cat which mine doesn't have.
Old Jan 26, 2017 | 08:00 PM
mattman1234's Avatar
mattman1234
could be for the air con air valve,re-circulate valve,think they have an air reservoir tank.
i could be wrong though
Old Jan 26, 2017 | 09:10 PM
grcossie's Avatar
grcossie
It`s a vacum reservoir, don`t remember what it was connected to
Old Jan 27, 2017 | 05:49 AM
BMrider's Avatar
BMrider
Thanks for your replies,
Yes, it seems to be part of the aircon system which is not working at present, I assume it will be ok to seal off the vac hose to stop an air leak?
Old Jan 27, 2017 | 09:42 AM
grcossie's Avatar
grcossie
No problem, just block the hose from inlet
