Clutch Bleeding
Old Jan 22, 2017 | 04:11 PM
Olli2004's Avatar
Olli2004
Default Clutch Bleeding
Evening All,
I've just swapped the engine in my 52 plate focus as I bought it with a knackered bottom end. It's all built back up but I can't bet the clutch to bleed back up properly.
It goes into gear fine with the engine off but when the engine is running its struggles to go in. When I initially bleed the clutch it seems ok with the engine running but the more I operate the clutch it then starts to struggle.
What's the best way to bleed the clutch?
Old Jan 22, 2017 | 05:26 PM
Caddyshack's Avatar
Caddyshack
I would use one of the sealey pressure bleeders, you pump it up and it is full of fluid, that pushes it through, I actually go one step further as I also have a suction one on the compressor, I connect both at once, open the bleed valve and push the pedal in a few times, I can flood a bottle through in no time so I think it works well.
Old Jan 22, 2017 | 08:00 PM
ray barker's Avatar
ray barker
Originally Posted by Olli2004
Evening All,
they usually bleed ok might be worth putting a new clutch m cylinder on it they cost fuk all there only plastic mine went i rang our local millauto quip who supply the trade arround here they wanted 80.00 looked on flea bay genuine ford ones seventeen quid make sure you at least use a pipe an bottle hold the bottle up high
Old Jan 25, 2017 | 02:18 PM
gcfcos's Avatar
gcfcos
This for sure
Old Feb 2, 2017 | 01:00 PM
steveo3002's Avatar
steveo3002
done mine a treat with a large syringe and some tubing , lower the level in the tank a bit then use the syringe to inject the fluid uphill , you will hear it bubble as the air comes out into the tank , 100ml size should do it fine and theyre a couple of quid on ebay
some folk use a brand new pump style oil can instead
Old Feb 2, 2017 | 01:21 PM
Caddyshack's Avatar
Caddyshack
Thats a good technique, never heard of that before but I like the simplicity
