2.0 Pinto. not running right
Old Jan 3, 2017 | 02:46 PM
100S's Avatar
100S
Default 2.0 Pinto. not running right
Hi Guys.
So I have a 1978, 2.0 Pinto with single weber 32/36 DGAV
Wasn't running right (Points had burnt out)
I've fitted new. Points, condenser, HT Leads, Dis cap, rotor arm, plugs.
Checked all vacuum pipes are clear.
Will start and run no problem but will only run flat out! / Like choke is on all the time. Will not tick over just cuts out if you tap the throttle.
So fuel is getting through fine. good spark.
Was running fine before points burnt out.
Any ideas what might be wrong?
Thanks Bryan
Old Jan 3, 2017 | 08:03 PM
ray barker's Avatar
ray barker
you said the points had burnt out before they dont usually burn out they get pitted check the timming static if want run propper try swopping the coil for one that you now is the wright one for it you cant bung any old one on some have ballast resister in them some cant run on them check youve wired the points proper with the insulating washer try another condenser you cant trust most f...ing idiots to send you the wright stuff check gap thats what i would be checking first
Old Feb 4, 2017 | 10:13 AM
radjay's Avatar
radjay
I would check for air leaks.
Changed the inlet gasket on mine but did not realise I had not cleaned the old gasket off properly.
Had a tiny gap and would cut out unless at half throttle and above otherwise would cut out.
