Cossie rev counter..
Old Apr 9, 2005 | 07:47 PM
Dave A's Avatar
Dave A
Polishing my 3 Escorts
Default Cossie rev counter..
My rev counter goes mad when I accelerate hard leaping up past 6k on off the scale!! I've changed the counter with another one but it still does it. Anyone know what else it could be???
CheeRS
Dave
Old Apr 9, 2005 | 09:57 PM
nicksaph's Avatar
nicksaph
is a 4x4? as mine does that sometimes the problem is userly the 3 multiplugs across the bulk head
Old Apr 9, 2005 | 10:34 PM
velocity's Avatar
velocity
very common problem on the sapphs,its caused by a stray signal getting in to the rev counter wire (the green one at the coil) and is know to be caused by bad earths in the loom and possibly the ignition amp and the 3 block connectors on the bulkhead,
best thing to do is remove and clean all the earths especially the one on the inlet manifold plenum,make sure the 2 halves of all the block connectors are pushed tight together,disconnect and reconect the ignition amp connector a couple of times to get a good connection,and check all connections on the coil for fraying and loosness
Old Apr 10, 2005 | 05:07 PM
richm's Avatar
richm
agreed with Velocity!!
if it's 4x4, pay special attention to the multiplug on the bulkhead (one of the 3) with the larger wires.
Old Apr 12, 2005 | 05:24 PM
Dave Henshall's Avatar
Dave Henshall
another favourite is the tdc sensor, this can make the rev couter bounce all over when it starts to fail, about 25 quid for a new one.
Old Apr 13, 2005 | 06:09 PM
rsjay's Avatar
rsjay
sorry to high jack your post but saves me starting a new one,
my rev counter is not working at the moment could someone tell me where it takes the signal from and what clour is the wire..
thanks
jay
Old Apr 13, 2005 | 06:32 PM
velocity's Avatar
velocity
what car do you have
Old Apr 13, 2005 | 07:19 PM
rsjay's Avatar
rsjay
Its a golf with a cossie engine,
its got a 2 wheel drive engine loom as it does not have the large connecters.
Old Apr 13, 2005 | 07:48 PM
richm's Avatar
richm
from the coil negative terminal, green wire.
Old Apr 13, 2005 | 07:50 PM
rsjay's Avatar
rsjay
cheers, was not 100% sure
Old Apr 20, 2005 | 12:56 PM
Dave A's Avatar
Dave A
Hi there - just wanted to thank everyone who replied to this. I finally got a chance to look at it and after 3 months of being totally p**sed off with the rev counter - it took all of 10 seconds to push together the 3 multiplugs properly and now it works perfectly!!! I can't beleive I played around with it so much when it was so simple!
CheeRS guys!
Dave
Old Apr 20, 2005 | 01:02 PM
richm's Avatar
richm
glad it's sorted! Just one of those funny quirks that you learn about that's so easy to fix once you know where to look!! lol
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
A.t.p
Sep 29, 2015 05:04 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
