ABS xr4x4 2.9i
Old Nov 29, 2016 | 10:09 AM
DaxRiders's Avatar
DaxRiders
Exclamation ABS xr4x4 2.9i
Hi, i've got a problem with my brakes.
The defaut ABS light is always on.
The brake pedal is hard. No brakes.
The fluid level is good.
Fuses good.
Relays good.
The pump ? i don't know. 12V 's ok. But no noise.
An idea ? Thx for your help.
( sorry for my english )
Old Nov 29, 2016 | 12:31 PM
martysmartie's Avatar
martysmartie
There is a pressure switch on the master cylinder, it's worth checking that this is closing, alternatively bridge the connector briefly, to see if the pump runs.
Martin
Old Nov 29, 2016 | 12:38 PM
james kiely's Avatar
james kiely
or maybe a sensor is broken
Old Nov 29, 2016 | 01:31 PM
grcossie's Avatar
grcossie
Have fixed this on some Cosworth`s, pressure switch on abs Block as a common fail, have also seen some broken wires from battery + to abs
