mk1 focus clutch bleeder access
need to try and do a clutch m/c in the morning, found some how to and it doenst look too bad
the bleed nipple...do i really have to half strip the engine bay to access this ? or can you reach from underneath ?
and im used to ye olde threaded ones you use a spanner on, this looks like plastic ? is it on threads still or whats the score ?
Don't tighten it with a spanner it will snap. Goes from open to closed in around half a turn too. As for access it depends how small your hands are but pulling the battery out is a 2 minute job anyway
Yeah man, i bought a very very cheap focus ,, clutch was gone , did the change, thought YES what a bargain, managed to even bleed it on my own, enough to get it going to get it done properly LOW AND behold I SNAPPED THE FREAKIN NIP ,now im chcuking it away
so be careful matey
so be careful matey
