Ford Rs Parts For Sale (Not cosworth, or Cvh Turbo) All Ford rs parts for sale in here that do not fit in the popular Cosworth or Cvh turbo sections. Starting a topic requires you to have purchased a gold membership.
RS2000 parts, some F2/Maxi/Kit Car, some not
Old Oct 24, 2016 | 10:52 AM
massivewangers's Avatar
massivewangers
Default RS2000 parts, some F2/Maxi/Kit Car, some not
A selection of RS2000 parts that I've acquired over the years but no longer require.
New speedo cable - £25
WP_20160924_18_32_12_Pro by Jon Scoltock, on Flickr
Two fuseboxes. Both MK5 I believe. One was removed from my rally car so is early MK5, the other looks the same to me and came with the car so I assume MK5 too. Neither have the stickers on with numbers. £40 a piece (the second one is currently being held for someone)
WP_20160928_15_47_16_Pro by Jon Scoltock, on Flickr
WP_20160928_15_47_26_Pro by Jon Scoltock, on Flickr
WP_20160928_15_58_47_Pro by Jon Scoltock, on Flickr
WP_20160928_15_58_52_Pro by Jon Scoltock, on Flickr
Custom throttle body inlet manifold. The best inlet you can buy for an RS2000, designed and CNC manufactured by someone on the RS2000 forum. It is nice and short to give more space and angled well for the head. I bought this as was planning to fit TBs to my rally car but have decided to leave the engine alone for the moment. Fits all the usual DCOE type throttles, so Jenvey, Omex etc etc. Cost for this was £250. It's never been fitted, so that's what I'd like for it.
WP_20160929_21_51_09_Pro by Jon Scoltock, on Flickr
More to follow in a second.
Old Oct 24, 2016 | 10:53 AM
massivewangers
Custom lightened flywheel done by Gary Black (Blacks of Stichill). This was an experimental piece that Gary did for me to see how light we could get a standard flywheel. Standard weight is usually 7.5-8kg, this one is just under 6kg. As above, I was going to fit it to my rally car but decided to leave the engine alone so no longer required. As this was an experiment, Gary didn't charge me for the work, so only asking £30 for it. Would be wrong of me to charge for something that I didn't pay for! This would need balancing to suit your engine, but that shouldn't cost too much.
WP_20160929_21_54_53_Pro by Jon Scoltock, on Flickr
WP_20160929_21_55_16_Pro by Jon Scoltock, on Flickr
MW-Flywheel-028 by Jon Scoltock, on Flickr
Mountune F2/Maxi/Kit Car crank pulley - £50
WP_20160929_21_59_22_Pro by Jon Scoltock, on Flickr
Mountune F2/Maxi/Kit Car external crank trigger bracket. Mountune discovered that, when revving these engines to high levels, the internal crank trigger wheel would fail, so they fitted an external system. This is the sensor bracket. Matman could probably make you a trigger wheel. £20
WP_20160929_22_42_22_Pro by Jon Scoltock, on Flickr
Still more to follow.
Old Oct 24, 2016 | 10:56 AM
massivewangers
Escort Kit Car/Maxi big wing, baffled sump. Has had additional material added to increase oil capacity along with a baffle plate to prevent oil starvation. Has had a couple of repairs in the past, but most of them have - £75
WP_20161009_16_24_10_Pro by Jon Scoltock, on Flickr
WP_20161009_16_24_16_Pro by Jon Scoltock, on Flickr
WP_20161009_16_24_23_Pro by Jon Scoltock, on Flickr
Dave Mac wide track driveshafts to suits RS2000/XR3i 130. Removed from my rally car. I've changed to a Focus gearbox so can no longer use these. They are 45mm wider than standard so ideal if you want to widen the track of your car. Use standard Escort joints - £100 for the pair
WP_20161009_16_06_39_Pro by Jon Scoltock, on Flickr
That's the lot. All prices are + P&P. Open to offers on everything as it's only taking up space.
