Alternator fault.
Old Oct 11, 2016 | 06:14 PM
Chopshop85's Avatar
Chopshop85
Default Alternator fault.
I've just fitted a new starter motor, and noticed the alternator isn't charging.
Is this something that can be affected by the starter or is it just coincidence?
Old Oct 11, 2016 | 06:29 PM
j6kyt's Avatar
j6kyt
check the wire from live on starter to alternator you have probably left it off.
Old Oct 11, 2016 | 06:34 PM
Chopshop85's Avatar
Chopshop85
just checked, they are all on.
There is no battery light when the ignition is on as well.
Old Oct 11, 2016 | 06:40 PM
j6kyt's Avatar
j6kyt
is it charging 14v at battery
Old Oct 11, 2016 | 07:14 PM
Chopshop85's Avatar
Chopshop85
No its not charging.
Old Oct 11, 2016 | 08:16 PM
martysmartie's Avatar
martysmartie
It won't be given what you have said, check the blue wire on the back of it.
Martin
Old Oct 11, 2016 | 09:05 PM
RichieST's Avatar
RichieST
Supposedly if the bulb blows it can stop it charging too as it breaks the circuit.
Old Oct 12, 2016 | 11:40 AM
martysmartie
It will, as the bulb forms part of the circuit, although I have never known one to blow.
Martin
Old Oct 12, 2016 | 12:00 PM
Chopshop85's Avatar
Chopshop85
checked the bulb and it was ok, and tried wiring the alternator straight to the battery and it started charging.So after exhausting all options it has to be the wiring somewhere. So I will have to do some exploring when the weather clears up a bit.
Old Oct 12, 2016 | 05:19 PM
slammedorion's Avatar
slammedorion
Brake lights work, I'm sure it's the same fuse? Check the fuse anyway, I had a short on my brake pedal switch causing the fuse to blow, and stopped it charging
Old Oct 12, 2016 | 05:36 PM
cabriolet's Avatar
cabriolet
the blue wire has connector on wing or under radiator it may look ok but have known the copper to turn to dust wont charge without warning light unless you rev the bollocks out of the car also check the charging wire between the starter and the alternator seen them suffer the same problem
Old Oct 12, 2016 | 05:53 PM
Cossy Mike's Avatar
Cossy Mike
Just done this on mine.
Thick red cable from battery to starter then it piggy backs to the alternator.
It earth's through the housing and the thin blue wire runs up the drivers wing direct the the back of the clocks.
It does sound like youv'e disturbed something
Old Oct 12, 2016 | 06:17 PM
Chopshop85's Avatar
Chopshop85
Yeah brake lights work ok.
Yeah i shall have to check the wires at the weekend.
I barely moved the wires when swapping the starter so one of the wires must have been on its last legs. As much of a pain as it is, it would have probably happend shortly anyway.
Old Oct 12, 2016 | 07:30 PM
martysmartie
Had it on mine (Cosworth) but the same setup, I rewired it.
What happens is the wire gets cooked by the turbo, it's worth checking whether you have power at the connector.
Martin
Old Oct 13, 2016 | 04:44 PM
Chopshop85's Avatar
Chopshop85
Ran a wire from the alternator to the back of the clocks. Got a battery light with ignition on and the alt is charging with the engine running.
Am I ok just to run a new wire straight from the alternator to the clocks? Save me trying to repair/replace the other in the loom.
Old Oct 13, 2016 | 07:21 PM
studabear's Avatar
studabear
Yes, like I told you 2 days ago.
Old Oct 14, 2016 | 03:09 PM
Chopshop85's Avatar
Chopshop85
Haha I'd forgot you told me till I re-read the convo. All sorted now
AndyStarks
Escort Range
Dec 29, 2016 10:14 PM
cossie330
18
Oct 3, 2016 07:34 PM
tomhoneyball
Ford Focus (All Models)
Sep 28, 2016 12:33 PM
James Brunt
Ford Focus Diesel
Sep 18, 2016 06:40 PM
