4x4 front diff bearing
Old Oct 10, 2016 | 04:40 PM
chrisa3's Avatar
chrisa3
Default 4x4 front diff bearing
anyone know how the bearing on the nearside diff housing on a 4x4 front diff gets lubricated? im assuming the gear oil flows along the shaft from the drivers side of the diff / sump as cant see anything in workshop manual suggesting it needs greasing.
Old Oct 11, 2016 | 11:11 AM
dojj's Avatar
dojj
Resident Wrestling Legend
the one in the casing for the speedo?
Old Oct 11, 2016 | 11:32 AM
chrisa3's Avatar
chrisa3
That's the one yes.
Old Oct 11, 2016 | 12:25 PM
dojj's Avatar
dojj
Shouldn't be lubed by anything from memory
Just a normal bearing
Old Oct 11, 2016 | 05:21 PM
chrisa3's Avatar
chrisa3
would have thought it was suppsoed to have some lubrication, plus the driveshaft seal must be there for a reason other than to prevent dust.
The manual doesnt state to grease it or anything so im assuming it must get gear oil from the other side, plus the speedo drive gear has an o'ring. f@ck knows , just wanted to double check before running it.
Old Oct 12, 2016 | 12:14 AM
dojj's Avatar
dojj
the shaft goes through the sump from one end to the other, but just like the diff has a seal to stop engine oil getting in so does the other side
4x4kiwi
Apr 15, 2021 04:22 AM
jonfoc
Ford Focus RS Parts for Sale.
Oct 12, 2016 06:03 PM
baz walton
Oct 8, 2016 10:41 AM
oilman
Trader Parts for Sale.
Oct 7, 2016 09:26 AM
Dr Jefferson
Oct 4, 2016 04:45 PM
