Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Starting issue
Old Sep 25, 2016 | 04:03 PM
Kennyh2000's Avatar
Kennyh2000
Default Starting issue
Start car in morning hot outside or cold outside starts fine. Switch car off when engine is warm after about 2 miles car restarts perfect. If engine is switched off when engine is cold then it's a basted to restart and sounds like no compression. Crank and crank for a while even ignition on and off and try to lock and unlock to make sure it isn't immobiliser issue and still won't start. After ages and ages of cranking then will fire up. Any thoughts?
johnboy73
Sep 16, 2016 07:06 PM
JoeyBoyden
Sep 12, 2016 12:18 PM
Bob Breeze
Ford Mondeo Including ST
Sep 10, 2016 08:11 AM
Shaunc
Sep 2, 2016 07:22 AM
