Shell – Big Turbo in Mallard green. Comes with all body workand all the interior including leather. The only thing missing is the banana pod gauges. Comes with Koni suspension, 60K gearbox with hydraulic clutch conversion, rear diffwith uprated diff hanger, morette headlights, all looms including engine loom,carbon fibre hockey stick and front splitter, spare wheel & cover, tool kit and towing hook. Basically a whole car minus the engine, rads, cooler, headertank and ECU. Also has the uprated 023 intank fuel pump. The car was featured in dec 2004 Fast Ford and was the cover car. It was also the car used to make alot of the Auto Specialist Escort Cosworth parts. Comes with a private plate,L600 SSY. Has a dink on the bonnet and a scuff on the bumper, otherwise a solid car. Only comes with steel wheels - Sold
All prices plus postage plus paypal fees or welcome to come and collect.
Siemens 55lb injectors used - Sold P8 ECU with MSD wasted spark kit including loom & MSD 55’s380 chip - Sold Mongoose full exhaust system - Sold Used Magnetti Marelli 3 Bar Map Sensor - Sold Auto Specialist RS500 intercooler - Sold Alloy Radiator - Sold Auto Specialist Turbo Cooler - Sold Alloy Header Tank - Sold Alloy Power Steering Tank - Sold Almost New Collins Engine & Gearbox mounts, done 20 miles at most - Sold Compomotive MO 1882 with good tyres - Sold Brand new BT set of boot badges, escort, rs & chrome cosworth - Sold
As said in the add, I have to put a price as per the rules but will consider serious offers. Bear in mind people want Ł3K to Ł4K for an engine in crap condition.
Engines basically brand new and built by one of the best builders in the country. Puerto is building my big power engine and has built Wenny's which you all k ie takes a fair bit of abuse. As the op says people are paying 3-4K for one that's been pulled out and old saph with no history! If you want a got and forget engine you just found it.
