Roof clock wires
Sep 6, 2016 | 09:40 AM
Roof clock wires
Morning all,
Has anyone had luck threading new wires up to the roof clock?
Any thoughts on how to would be helpful!
Thanks,
Lee
Sep 6, 2016 | 11:51 AM
i use a stiff bit of wire or coat hanger
go from the top of the pillar down
Sep 6, 2016 | 12:46 PM
As above, stiff wire from the top then feed it all back up
Sep 6, 2016 | 02:30 PM
as above, I used to build cars in a factory and thats how its done when they're being built new.
Sep 6, 2016 | 06:37 PM
Cheers lads,
So I'll peel the headliner back to the A pillar and feed a thick wire down from there.
Thanks again!
Lee
Sep 6, 2016 | 07:58 PM
May need front screen out if your dropping the head lining?
I'd try just taking a post cover off and using the wire to fish it through
With the wire try putting string down the route first, then you can pull the loom up with it
Sep 6, 2016 | 08:30 PM
Quote:
Originally Posted by
slammedorion
how are they removed though?
Lee
Sep 6, 2016 | 08:58 PM
Door seal off around a post area, and pull carefully from under windscreen seal
You'll have to take the speaker out of the footwell too
Sep 6, 2016 | 10:09 PM
if you have a sunroof you can drop the headlining from there and it should work
faz_cossy
Jul 21, 2016 12:28 AM
MMartin
Ford Fiesta
Jul 5, 2016 09:35 AM
cossiejonjon
Jun 30, 2016 04:47 PM
Hayley Fields Scrupps
Jun 12, 2016 09:21 AM
rsturbo27
Jun 9, 2016 10:10 PM
