Omex 600 Start Issues
Old Sep 4, 2016 | 12:35 PM
Wardy ZS's Avatar
Wardy ZS
Default Omex 600 Start Issues
Trying to start my Fiesta, but I'm having issues.
Start sync has remained on no, I've fitted a new crank sensor, hoping that would resolve the issue, and found a flow chart on another forum that suggested changing Mx Start by 15, but to no avail.
Can anyone make further suggestions?
I've took a picture of the data, one thing that doesn't seem right is MX Time Start is set a 0.
Old Sep 4, 2016 | 01:04 PM
S2RST1987's Avatar
S2RST1987
does it show live values I.e coolant temp or rpm when turning over?
i had the same issue last week and it turned out that the data was not sending to ecu and storing properly.
Old Sep 4, 2016 | 02:10 PM
Wardy ZS's Avatar
Wardy ZS
Was showing coolant and air temps, didn't look at revs.
Are the revs link to crank sensor?
Old Sep 4, 2016 | 03:13 PM
JOHNDQ's Avatar
JOHNDQ
Yes rpm should be a few hundred at crank pick up is via the crank sensor
Old Sep 4, 2016 | 03:50 PM
markk's Avatar
markk
You need to set the logging up, live data high speed on cranking, you need to look for the crank teeth count and that the cam tooth counts zero-one-zero one etc
Old Sep 4, 2016 | 08:04 PM
Wardy ZS's Avatar
Wardy ZS
Been out again, checked the wiring, and was done from the ECU to the multi plug, then checked multi plug to the sensor, and was a fault.
Replaced the loom with a spare and success! Sync stat to yes!
Too late to try and start it, that's tomorrow's job.
R12KTM
Apr 10, 2016 08:29 AM
FORD RS MAD
Modellers Corner.
Apr 1, 2016 04:03 PM
paceo
Mar 23, 2016 05:28 PM
Gooey
Ford Classics & Vintage
32
Dec 5, 2003 01:38 PM
tockwell
12
Nov 24, 2003 04:31 PM
