Cosworth Cutting out when cold!!
Old Aug 31, 2016 | 09:11 PM
adam151082's Avatar
adam151082
Default Cosworth Cutting out when cold!!
Hi Guy's,
I've got a problem with my car. When i start it from cold it will hunt (rev up and down) and then cut out unless i drive it for 1-2 minutes and then its fine.
I've cleaned the ISCV and checked its getting power and all seems well.
Any ideas??
Old Aug 31, 2016 | 10:05 PM
martysmartie's Avatar
martysmartie
I have the same problem, and it's always done it, which is annoying.
I think the valve is faulty, but it's hard to find the original ones and unless new, it's likely to have the same issue.
A few years ago, I got an aftermarket one, but this was worse than the original, as it run too fast, I figured the springs were not of the correct specification, but even messing around with them, it still would not work right and so I put the original back on.
Martin
Old Apr 16, 2017 | 12:29 PM
adam151082's Avatar
adam151082
Can anyone shed any more light on this?
Old Apr 16, 2017 | 12:39 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Is the idle 100% stable once warm? does it dip at all? If so then the main throttle body butterfly wants opening a touch to support the base idle speed with a touch more air.
Old Apr 16, 2017 | 02:16 PM
bigdel's Avatar
bigdel
Mine's exactly the same. won't idle at all when cold, but after a minute with my foot on the throttle keeping it at about 700 - 1000 rpm, it's fine, if still a little lumpy. Once fully warm though, it idles perfectly.
Old Apr 16, 2017 | 03:53 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
Do not adjust the throttle stop screw the base idle is adjusted via the idle by pass air bleed screw
Old Apr 16, 2017 | 04:06 PM
Sierrasideways's Avatar
Sierrasideways
Can't you get them new from GGR?
Old Apr 16, 2017 | 05:19 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Thats what i meant. Yes do not adjust the butterfly it will put your tps out. ta Tone
Old Apr 16, 2017 | 07:16 PM
ray barker's Avatar
ray barker
i bought an after market icv recently it works fine but my old one did all but stop. there is a procedure for setting the idle its not just moving the butterfly
Old Apr 25, 2017 | 10:25 PM
3doorcozmess's Avatar
3doorcozmess
my car does the oppsite.
starts up fine for a few minutes then starts to hunt then when really warm it's fine again
si
xr4x4c
May 2, 2016 10:07 PM
L33_srd
Apr 4, 2016 03:42 PM
Brickhouse
Mar 4, 2016 05:13 PM
YBJ
Feb 29, 2016 08:37 PM
Dec 19, 2003 01:32 PM
