s2 still rattle from rome
Old Aug 30, 2016 | 03:27 PM
Marino's Avatar
Marino
Default s2 still rattle from rome
hi guys,
it is one year that I try to solve a knock problem at low revs.
I rebuilt the engine 3 times because of a faulty set of rings, from that moment when the engine is hot starts to knock at low revs for a short time, but as soon as the boost starts to rise the noise disappears. I mounted a wideband to monitor afr:
idle 14:00
cruise 14.5
boost wot 12.5
I think it is correct?
I tried to retard the timing to 6 degrees but nothing.
I'm going crazy.
any suggestions?
Old Aug 30, 2016 | 08:33 PM
studabear's Avatar
studabear
Does the waste gate actuator have a little preload. My car had a rattle years ago that was caused by no tension on the waste gate.
Could be barking up the wrong tree, but its free to check.
Old Aug 31, 2016 | 04:07 PM
Marino's Avatar
Marino
the actuator is new, it was replaced because the old one had become soft and i was only 0.3 psi of boost.
when I replaced the actuator I have given the usual half-hole preload.
can it be a turbo problem?
Old Aug 31, 2016 | 06:13 PM
VEEDUBBED's Avatar
VEEDUBBED
Are you in Rome mate? Anywhere near Trastevere station? I'm in Monteverde vecchio, maybe you could pop around and I could have a listen.
Ciao-Andrea.
Old Aug 31, 2016 | 09:07 PM
Marino's Avatar
Marino
Ciao-Andrea.
hi mate
i'm in CENTOCELLE. do you know where is it?
it would be nice to meet you
Old Aug 31, 2016 | 09:55 PM
tony66's Avatar
tony66
Default knock
i had a we knock off a mk3 rs turbo many years ago sounded like a noisy tappet-turned out it was a spun big end shell,only a slight noise but carnage within...
Old Sep 1, 2016 | 01:07 PM
VEEDUBBED's Avatar
VEEDUBBED
Tony read my thoughts, I was thinking small ends.. I had a Carlos saint Celica turbo do the same thing. Also blew up an old 1.3 fiat uno turbo tho way, buggered conrod small ends..same noise.
Marino, non ci crederai, sono Passato ieri pomeriggio proprio li davanti sulla Prenestina! Stavo andando a Castelverde per un colloquio per la mia ragazza.. Caxxo se il mondo è piccolo.
Appena mi sono liberato un po del lavoro ci possiamo incontrare certo, ho l'impressione che tu sei uno dei pochissimi proprietari del Escort rs turbo..
Old Sep 2, 2016 | 01:20 PM
Marino's Avatar
Marino
so, can it be an engine problem?
bad thing,i will have to remove the engine again. that s**ks
the problem is the head: it was skimmed 3 times and and i think that skim the head one more time will raise the CR too much.
ciao andrea, peccato.... vabbè avremo altre occasioni per incontrarci.
ciao maurizio
Old Sep 8, 2016 | 12:39 PM
akronos's Avatar
akronos
Anche io Italiano di Pisa piacere!
Carlos-Titx
Insurance
Mar 8, 2016 09:43 PM
Will Pedley Racing
Ford Focus ST Parts for Sale
Feb 24, 2016 05:22 PM
gurnE
Nov 22, 2003 06:54 PM
CosRush
Oct 13, 2003 11:56 AM
