Adjustable tca,s ABS block, front diff, swirl pot.
I have had a bit of a clear out and have these bits for sale:
Inlet manifold off my 4x4 Ł40 posted SOLD
Front diff, done 32,000 miles. Came off my 4x4 all standard, I only took the cover off to look inside. No noises and was working fine, I just swapped it for a quaife one.
Ł65 plus Ł10 postage
4 (dark) green injectors, came off my 4x4 that was around 330bhp, removed by Mark Shead when he upgraded my engine. Ł50 posted SOLD
Swirl pot in ally, make not known, will polish up<br/>Well. It looks to have had one side cut down and a few marks but will clean up and works well. I bought it whilst waiting for my spec r one. Ł30 posted.
These would probably sand and polish out and are not seen when fitted
4x4 ABS block comes with the bits below in the pic, ECU, one or Two abs sensors, Ecu plug. Ł40 posted
Part number on block. I had this working on my car.
Ecu part numbers
Ecu plug
Air Fuel ratio, as you can see it has been used. The wires are there and some like live and neutral are obvious. The others I assume go to lambda. I am sure some googling will show the wire diagrams so I will try to find them. This was working in my car. Ł20 posted
Air fuel ratio wires
Pair of Cossie 4x4 adjustable Track Control Arms taken off my car, one of the boots has split but easy to get from a motor factors Ł35 posted.
I also have a Greddy boost controller and will put up a pic when I find the wires for it....no idea what that is worth?
I just found the wiring instructions for the Lambda, the interested buyers inbox is now full though. Here is the wiring instruction link: http://autocar-electrical.co.uk/imag...nstruction.pdf
Standard supra diff cover, has recently been painted. Ł40 posted
I gave the swirl pot a quick wipe over with auto sol
Cleans up ok, you could easily wet sand it for better results
I have just found my old NON adjustable track control arms, they are Ł15 posted if anyone wants them. I also have a 4x4 front anti roll bar, obviously quite heavy (no mounts or brackets though)
original
14
Aug 19, 2016 11:40 PM
CrOwSoN15
Jul 8, 2016 06:34 AM
