2wd saff on its way
Old Aug 20, 2016 | 01:55 PM
3doorcozmess's Avatar
3doorcozmess
Default 2wd saff on its way
Here we go again..
Bought another stage 1 cosworth about 18months ago and decided to mod, stage one is not enough lol. I've had a few 400bhp cosworth cars over the years but want more power now.
Started with the backend and running gear. MK rear beam, MK diff mount new tank, new fuel pump cradle, new bearings, Polly mounts, rebuild drive shafts, big tooth gearbox, uprated diff and rebuild balanced prop.
Cleaned and resealed the bottom car it was mint underneath I really wanted to concourse the bottom but then thought whats the point I want to drive it not worrie about cleaning it.
I also bought another engine to build up so i can still use the car. That didn’t turn out well, cracked block so sold it on ebay and got 250 quid back. I sourced another mint standard bore 200 block so back on track. I did buy the engine knowing I wanted to rebuild but just didn't see the crack which is a pisser it even had the pump drive missing from inside the block so would of gone back any way. It wasn’t all a disaster the crank and head were mint, 138.9mm on the head.
Here some pictures I’ve been taking though the build, hopefully the engine will be in the car 2weeks, run it in then up to the tuners for mapping.
bought this not keen on the polish look painted and bored out
Bloody cracked block
New block
Few Lights Lol
Engine getting built
Problem with the alternator to close had to buy a drop bracket from Anembro
Engine as it stand now just a couple of bits left to do
File Type: jpg
Old Aug 20, 2016 | 02:21 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Looking good nice project
Old Aug 20, 2016 | 02:23 PM
Jay,'s Avatar
Jay,
Sponsor
That looks smart ! Are you wrapping the exhaust manifold ? and is that a 7670 ?
Old Aug 20, 2016 | 02:25 PM
3doorcozmess
7064, and wrapping the tube closest to the alternator
Old Aug 20, 2016 | 02:31 PM
BIL N KEL's Avatar
BIL N KEL
Very nice bud what spec is your engine and what power are you expecting? My last Saff was 400bhp, I'm currently building the my first Cossie up again as I broke it to build my grey one. I'm undecided on what power to run, I'd love to see what 500bhp is like but on the other side I'd like a nice reliable car I can use regularly
Old Aug 20, 2016 | 02:39 PM
Staffi's Avatar
Staffi
Very nice indeed.
Old Aug 20, 2016 | 02:51 PM
rooos's Avatar
rooos
awesome work!
gonna keep an eye on it...
Old Aug 20, 2016 | 04:04 PM
visa_broke's Avatar
visa_broke
10 Year Member
very nice
are you going to brace the turbo/manifold, was quite surprised to see how far out the manifold places the turbo. Looks a lovely bit of kit though!
Old Aug 20, 2016 | 04:41 PM
Lovely ,keep the updates coming
Old Aug 20, 2016 | 04:54 PM
Jay,'s Avatar
Jay,
Sponsor
To save you time lol I thought that too but ended up wrapping it all as it also sits very close to the servo
Old Aug 20, 2016 | 05:01 PM
siscossie's Avatar
siscossie
3-door moonstone
Engine looks great fela
Old Aug 20, 2016 | 05:12 PM
3doorcozmess
Ported and flowed head
Double valve Springs
Bd14 inlet
Mahle 4x4 pistons with cuts
Balance bottom end
Light weight burton fly wheel
Long studs
WRC head gasket
Ported throttle body
100mm Airtec intercooler
EFR 7064 external gated
Autronic sm4 ecu
1000cc injectors
Old Aug 20, 2016 | 05:13 PM
3doorcozmess
Originally Posted by visa_broke
very nice
Currently making a turbo hanger.
Old Aug 20, 2016 | 05:27 PM
Jay,'s Avatar
Jay,
Sponsor
I havnt used a hanger Mark said it would be fine
Old Aug 20, 2016 | 05:47 PM
3doorcozmess
He told me that too.
I just like to look of it and peace of mind there's a lot of weight on that side.
Old Aug 20, 2016 | 06:10 PM
Ridgey's Avatar
Ridgey
Engine looks great, glad you sorted the alt clearance
Old Aug 20, 2016 | 06:53 PM
gcfcos's Avatar
gcfcos
That looks stunning. Gonna be a beast by the looks of it!
Old Aug 20, 2016 | 09:05 PM
Nice car. Will be a monster of an engine.
Old Aug 20, 2016 | 10:42 PM
3doorcozmess
I should just wack the 7670 on and should achieve 580ish but the torque is roughly same or sometimes lower than the 7064?
Mark MAD recently mapped a saff on a standard engine which had a Hart/AS inlet, spec r cooler and that was 477bhp and 545lb torque so hopefully with a worked head and cam I may see the 500bhp?
Old Aug 21, 2016 | 08:02 AM
bluntys1rsturbo's Avatar
bluntys1rsturbo
Boost addict
that looks like a cracking build and spec fella, dont get to caught up on numbers im sure it will be spot on once mapped defo have all the right bits to make a very quick car.
look forward to the updates
Old Aug 21, 2016 | 12:11 PM
3doorcozmess
Cheers, only part that my let it down is the inlet. I'm running a 4x4 with 10mm spacer. If that holds it back will change to a AS inlet.
Si
Old Aug 21, 2016 | 07:37 PM
1374lee's Avatar
1374lee
That looks superb, really nice bit of kit.Keep the updates coming as and when.
CheeRS.Lee.
Old Aug 22, 2016 | 05:58 AM
bluntys1rsturbo
Boost addict
Si
i suppose the beauty of it is you will be able see if the inlet holds it back when its being mapped. And if it does restrict it its pretty easy to sort out and have a map adjustment
any idea when its going for mapping fella?
Old Aug 22, 2016 | 05:44 PM
3doorcozmess
It was booked in start at the start of August. But the build has taken longer than i thought and dont want to rush the builder.
I'm not going to book in for mapping until the engine is in the bay now. hopefully will be booking in approx 3 weeks time for when ever M.A.D are ready.
Si
Old Aug 23, 2016 | 03:24 PM
Mondi-DZK's Avatar
Mondi-DZK
State of Art mate.
Old Aug 23, 2016 | 06:00 PM
3doorcozmess
Hanger is made
Old Aug 23, 2016 | 11:09 PM
Jules44's Avatar
Jules44
10 Year Member
Nice build, what did you paint the floor with?
Old Aug 24, 2016 | 09:08 AM
3doorcozmess
Jet washed with an air line and brake cleaner then black waxoil from Halfords
Old Aug 24, 2016 | 09:19 AM
DaveCrack's Avatar
DaveCrack
Nice build!
Old Aug 26, 2016 | 10:17 PM
3doorcozmess
Originally Posted by DaveCrack
Nice build!
Cheers getting there.
Old Sep 9, 2016 | 06:14 AM
3doorcozmess
Been trying to sort out the last piece of the puzzle which has been the oil drain back. I bought a pipe with a 3/8 npt fitting which goes into the turbo but the other end doesn't fit over the sump end I'd have to cut off and weld on a AN10 fitting so my engine builder decided to make the pipe instead which I should of just done in the first place engine would of been done 2weeks ago.
Old Sep 10, 2016 | 08:31 AM
3doorcozmess
Engine all done now oil return on, exhaust wrapped, just the oil filter left which I'll collect on Monday. Then just got to wait for the builder to drop it the hole.
Only thing I'm not sure on now are the hose's. I've bought grey pro hoses but they look nothing like colour seen on the web. Pro hoes are happy to take back and replace for black but I didnt want black or blue I want to be a bit different. I know samco do grey but not sure who to use to purchase and knowing samco they will be double the price.
Any way how she looks now.
Old Sep 10, 2016 | 09:31 AM
london_chris's Avatar
london_chris
i quite like the hoses, but theyll be a bastard to keep clean.
Old Sep 10, 2016 | 11:07 AM
3doorcozmess
Brake cleaner, clean everything lol
Old Oct 1, 2016 | 08:44 PM
turbotrev's Avatar
turbotrev
Looks fucking awesome Bruva!!!
Cheers Paul
Old Oct 2, 2016 | 09:34 AM
3doorcozmess
Cheers Paul
Cheers paul. Theres a couple of fast cossie powered cars around my way i need to keep up.
Old Oct 2, 2016 | 09:41 AM
costina's Avatar
costina
Live long and prosper!!
I see what you mean about hoses they look light blue rather than grey.
Very nice tho.
Old Oct 2, 2016 | 09:45 AM
james kiely's Avatar
james kiely
that engine looks a very cool piece of kit ,great job
Old Oct 2, 2016 | 09:50 AM
turbotrev's Avatar
turbotrev
I'm sure the tables will turn with that setup mate!
Cheers Paul
Old Oct 2, 2016 | 09:52 AM
turbotrev's Avatar
turbotrev
I actually like the colour of the hoses, individual too
Cheers Paul
