advice on frst
Fiesta rs turbo running rough what would cause rough running? It's had full service new plugs leads coil pack new battery alternator checked fuel pump getting the volts loom checked and earth's cleaned new cold start sensor tried a known set of good injectors and no difference it's running ofab with 3 bar map and t3 but otherwise std
Back in the day I had a similar problem with my FRST, ended up at Turbosystems where they sorted it no problem..........believe it or not it was all down to dodgy supressors that Ford decided to put on everything to stop radio interference - different car when these had been removed and to be honest made no difference to radio reception at all.......think the main offender was one on the map sensor if memory serves me right.
paceo
Mar 23, 2016 05:28 PM
RSmark84
Feb 28, 2016 04:33 PM
