DCOM Weber carbs, facet fuel pump, FilterKing competition regulator, -6 AN fittings
DCOM Weber carbs, facet fuel pump, FilterKing competition regulator, and mount, Torques AN -6 hoses and fittings
• Two matched DCOM Weber carburettors (superior to DCOE carbs as they have a diaphragm pump) recently stripped and completely rebuilt. Jetted for a 2.0 ZVH engine, comes with trumpets
• Weber throttle linkage
• All AN -6 fittings for plumping the carbs – AN unions have been machined to fit carbs.
• Inline pressure gauge
• FilterKing Competition pressure regulator with -6 tales and all required AN plumping, with pressure gauge.
• Facet Silver Top fuel pump with -6 tales and AN plumping, and rubber mounts
• Alloy bracket for mounting the regulator and fuel pump
• Pre-filter
• 4m braided hose for the above
£500 for everything, will consider splitting.
• Pre-filter
Windle
31
Feb 16, 2004 11:24 PM
