Need information on ofam ecu
I'm planning on running ofam ecu but I've emailed them and had no reply I've heard they might be members on herebut wondering if anyone can point me in the right direction of talking to one of the people that make then thanks
Hi
You need lambda sensor for setting up.
Map sensor is built into ecu and can be upgraded to 4 bar dependent on your spec also you do away with the co port
Hope this helps, but message rob on here and he will get back to you
Mark
Mark
