Twin turbo cosworth 24v v6 engine gearbox ect
Old Jul 5, 2016 | 08:55 PM
driftsaff24v's Avatar
driftsaff24v
Default Twin turbo cosworth 24v v6 engine gearbox ect
I'm selling my twin turbo cosworth 24v v6 engine, rwd gearbox and Ecu
2.9 24v boa engine
Lightened and balenced bottom end
Arp rod bolts
Pistons machined to take 12valve piston rings as they have larger oil rings
High pressure oil pump
Lightened flywheel with 6 paddle clutch
Heads machined to drop compression to 8:1 ratio
3 Angle valve seats
Solid lifter conversion
One off piper camshafts
One off inlet manifold
650cc injectors
X2 t28 turbos
Emerald k3 Ecu
Mapped at half a bar of boost and producing 330bhp 380nm torque
With a electronic boost valve fitted would see 400+ at a bar of boost
Mazda rx8 6 speed gearbox with adaptor plate to fit the v6 engine and brackets to run clutch cable or can run hydraulic clutch using rx8 slave
Only removed from the car as going down a different route with the car now
Bottom end was stripped and checked after removal and a fresh set of shells fitted and new arp rod bolts
£3000 ono
Old Jul 6, 2016 | 09:36 AM
R4N SS's Avatar
R4N SS
if you strip it for parts i will have the turbo conversion mate
Old Jul 6, 2016 | 10:38 AM
driftsaff24v
The whole lot is a turbo conversion mate low compression engine turbo camshafts Ecu the lot
Old Jul 17, 2016 | 07:03 PM
turnover's Avatar
turnover
I've pmd about 5 days ago pal need a contact number thanks
Old Jul 17, 2016 | 07:12 PM
jim_robson's Avatar
jim_robson
Tight cunt lol
Old Jul 17, 2016 | 07:19 PM
driftsaff24v
Hi sorry I haven't got back to you sorry but I've decided to keep it the engine now
Old Aug 3, 2016 | 10:41 AM
R4N SS's Avatar
R4N SS
the pics of the engine in the car show a different inlet - is that not coming with this?
Old Feb 9, 2020 | 03:11 PM
Michael James Cooper's Avatar
2.9 24v boa engine
Arp rod bolts
3 Angle valve seats
650cc injectors
X2 t28 turbos
Emerald k3 Ecu
="6"%£3000 ono
Attachment 17611
Attachment 17612
Attachment 17613
Attachment 17614
Hi
Is engine and gearbox still available
Thanks
Old Feb 9, 2020 | 05:05 PM
BIG LEE's Avatar
BIG LEE
Originally Posted by Michael James Cooper
Hi
Thanks
ads from 2016
cos elle
33
Jan 31, 2018 05:18 PM
mk2 escort boy
Mar 9, 2016 05:47 PM
Rsturbo519
Feb 22, 2016 07:23 AM
B19-TRB
Alloy wheels and ICE for sale
Dec 31, 2003 08:43 AM
