Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
mk6 air box mods
Old Jun 21, 2016 | 08:16 AM
bridgeman's Avatar
bridgeman
Default mk6 air box mods
Hi I have a 2005 mk6 with the large air box on top of engine !! is there any mods you can do to the air box apart from fitting a k& n filter etc .???
Old Jun 21, 2016 | 10:13 AM
_Jimmy_'s Avatar
_Jimmy_
What do you want to achieve? Better performance without the extra noise?
What model?
Maybe you could try and fit something like an st170 airbox onto it if you can squeeze it into the bay, less pipework turns and moves it away from the engine for reduced temp. Might have to look at relocating the battery though if space is too tight, and lining up with the throttle body on the front of the engine would take some thinking about.
Mattcortina
May 14, 2016 07:59 PM
voodoo333
Ford Focus Diesel
May 8, 2016 12:02 PM
JoshXR2
May 2, 2016 05:37 PM
Mk6fez
Apr 3, 2016 05:09 PM
