Ford Range This section is for other models in the Ford range.
Ford Ranger
Old Jun 16, 2016 | 08:18 PM
Arnie10's Avatar
Arnie10
Default Ford Ranger
Hello everyone,thank you for allowing me to join, I have a ford Ranger 2.5 diesel 4x4 xlt, it has been a brilliant truck for years, but recently it has developed a strange misfire when starting from cold, after a short while and it runs perfectly. I have replaced the glow plugs,air filter and fuel filter I have cleaned the egr valve, and run some injector cleaner through the fuel system, but non have improved it. It is also strange to note that whilst it is running rough if I depress the clutch pedal instantly the misfire disappears, then release the clutch and it returns, I am confused.
I have a obd11 code reader and I bought a converter to plug it into the diagnostic socket under the bonnet on the passenger side but I didn't have any display on the reader at all, I do not know why it didn't work but I plugged it into my VW and that worked ok.
I would be very grateful of any input from anyone here who has some info that could help me.
Thank you for reading.
Old Jun 17, 2016 | 06:28 AM
stu20004x4's Avatar
stu20004x4
mk6 escort fantasist
Changed the spark plugs and leads?
Old Jun 17, 2016 | 07:46 AM
Arnie10's Avatar
Arnie10
No I haven't as its a diesel but did change the glow plugs, but thanks for your reply.
plumberdave
Mar 26, 2016 06:54 PM
cozzy jeff
11
Mar 20, 2016 07:47 PM
peterblue
Mar 20, 2016 11:11 AM
purpleka
Ford KA
Mar 19, 2016 07:46 PM
j@mie
Mar 19, 2016 07:08 PM
