Help with Clutch Pedal!
Jun 16, 2016 | 10:29 AM
Hello i'm Mark from Italy! I buy a new clutch quadrant, install perfect, but the spring.....I do not know where it goes inserted.
One part it fits into the quadrant but...the other end?!
Jun 16, 2016 | 10:43 AM
does it not go into the triangular hole shown in your last picture.
Jun 16, 2016 | 10:48 AM
Yup the triangular hole in the pedal itself
Jun 16, 2016 | 11:33 AM
really? the spring is short and hard. i can not get her into the slot.
Jun 16, 2016 | 11:34 AM
Thats the point... its tensioned. Use a flat blade screwdriver to pull the spring down. Its not 'that' difficult
Jun 16, 2016 | 11:55 AM
I pulled mine through the hole with 'hooped' metal wire
Jun 16, 2016 | 11:57 AM
Quote:
Originally Posted by
anthony lea
The hole I used was on the front of the pedal.
Also is your quadrant the wrong way around in the pic?
Jun 16, 2016 | 12:13 PM
anthony lea
Good spot!
Jun 16, 2016 | 03:20 PM
you say that the qudrant is in the wrong location ?
Jun 16, 2016 | 03:30 PM
Jun 16, 2016 | 03:36 PM
anyone can make a photo please? If i flip the quadrant it's not correct...:-(
The other end of the line where enter? I need to uninstall the k jetronic?
Jun 17, 2016 | 10:52 AM
Jun 17, 2016 | 11:08 AM
oh! thanks a lot!
The other end of the cable? It's end under the k jetronic? I must remove them?
Jun 17, 2016 | 11:39 AM
You should be able to reach down there. Its right on the top of the box, not that difficult to access/reach
Jun 17, 2016 | 04:00 PM
Jun 17, 2016 | 04:05 PM
Look on top of the gear box...
Jun 18, 2016 | 12:32 PM
The top of the gearbox are under k jetronic...hide...
Jun 18, 2016 | 11:54 PM
Shaunc
Jun 1, 2016 04:56 AM
purplefocus
Ford Focus (All Models)
May 25, 2016 06:01 AM
Bradley Clive Dermott
May 23, 2016 06:37 PM
Pitbull69
May 22, 2016 02:49 PM
