cosworth parts
Cosworth parts for sale all are plus post or collect and will add pictures when asked
4x grey injectors in vgc £170 SOLD
garrett t34 .63 exhaust housing has back and forward play and little side to side play £300 SOLD
Escort cosworth bt 4x standard size Piston and gudgin pins £100
Escort cosworth bt Throttle body £50
Escort cosworth bt inlet/Exhaust Cams £100
escort cosworth under carpet polystrene mould £50
escort cosworth boot floor carpet £100
escort cosworth pas metal pipe £30
escort cosworth header tank £25
escort cosworth front fog switche £5
escort cosworth rear heated window switche £5
escort cosworth rear arb clamps £15
escort cosworth abs pump £50
escort cosworth driver side wheel arch boot carpet £25
escort cosworth a pillar gauge pod with two hole for led lights £15
escort cosworth a pillar gauge pod £20 SOLD
escort cosworth cosworth A pillar covers L/R £25
escort cosworth cosworth sill trims 3 x drivers side 1 x passenger side £15 each
escort cosworth fuel tank £100
escort cosworth BT intercooler £50
escort cosworth front ARB x2 £30 each
escort cosworth pedal box £20
escort cosworth door windows L/R £20 collect only or sort own courier
escort cosworth metal fuel plpes feed and return from under the car £50 collect only or sort own courier*
escort cosworth inside plastic boot trim £30
escort cosworth hand brake lever £5*
escort cosworth oil pick up plpe £20
escort cosworth rear diff mount vgc £25
escort cosworth bonnet catch £10
escort cosworth front brake pipe brackets L/R that bolts up with engine cradle £10 SOLD
escort cosworth forge motorsport oil breather £100
escort cosworth forge motorsport cooling swirl pot £60
escort cosworth fuel regulator bosch as new put in but not run £40
escort cosworth fuel regulator used £25
escort cosworth plastic header tank £20
escort cosworth interior roof light £5
4X cosworth speed max con rods as new Not used £100
cosworth 2wd fuel rail £20
cosworth intercooler to throttle body graham goode racing hose in blue £20
sapphire cosworth front grill no mesh £20
cosworth 2wd forge motorsport header tank £120
cosworth 2wd power steering cooling metal pipe £25
cosworth 2wd steering column UJ x2 both need new bushs £20 each
cosworth 2wd gearbox cradle £15
cosworth 2wd rear ARB £15
cosworth 4x4 engine cradle £30
cosworth turbo oil return pipe £30
cosworth steering rack cradle modified by MK Motorsport to work with WRC engine mounts £50
cosworth powerflex yellow front top shock bushers like new £25
sapphire cosworth moonstone blue doors in gc £20 each
cosworth 2wd engine cradle £20
cosworth 2wd front ARB £25
cosworth sapphire head lights vgc £40
will be adding more as i go
Does this mean I can finally get the picture of the Escort Cosworth front arb and what the shipment costs to the Netherlands are? As i've asked you several weeks ago on the escort forum.
3doorcozmess
Apr 20, 2016 07:20 AM
TomPengelly
Mar 3, 2016 11:38 PM
lamar69er
Oct 3, 2003 03:47 PM
