Rs 1800 to cvh efi turbo ?
I have a rs 1800 xr2i and have a cvh mfi turbo engine would like to make a efi cvh engine to put into the fiesta anyone know where to start I.e loom and weather the inlet manifold off the zetec engine will fit the cvh engine many thanks am new to all this so as simple as possible would be great full 😎
Depends on your budget I think. i might be tempted to fit the RS turbo manifold to the Zetec head, sort the oil return, intercooler and breathers and just run it on acouple pounds of boost. I would also put a modern management on it. I think whatever you do I would'nt bother with the MFI
Adder
Adder
I dont really no tbh, I guess your off to a good start with it being the RS 1800 130 bhp ? If you could squeeze 130/140 road wheel horse power that would be good. I think im right in saying that you can get the Forged pistons from the VW turbos to fit if you wanted more boost but this i think is where the aftermarket management would probably be needed. I personaly would'nt be bothered about running over 200 brake on the old BC gearbox tho.
hope this helps
Adder
hope this helps
Adder
admanrs
Mar 20, 2017 07:21 PM
paceo
Mar 23, 2016 05:28 PM
