Alternative to dump valve on modified 2wd cosworth
Old May 31, 2016 | 09:29 PM
155lee's Avatar
155lee
Default Alternative to dump valve on modified 2wd cosworth
After getting my car finished and motd after a winter resto I have found that running the car without the standard recirc valve or a dump valve is hugely annoying.
The turbo chatter is great for a little while but it's irritating now.
I don't want a dump valve so what are the alternatives and how will it plumb up as my car is modified.
T35 turbo,rs500 size intercooler,samco hoses with d/v take off and I want to refit the standard airbox.
Could I buy a forge or similar re circulation valve and take the outlet to the old breather connection on the standard airbox???
as my car has a bailey breather so that connection will be redundant.
Any tips or pics would be great.
Ta,lee
Old May 31, 2016 | 09:45 PM
fraser9764's Avatar
fraser9764
Turbosmart Kompact dual port.
I'm tempted to blank off the atmospheric side with the plug that's supplied with the valve.
Old May 31, 2016 | 10:04 PM
155lee's Avatar
155lee
That looks exactly what I need.
Where did you get the crossover pipe from?
Does st's do that boost hose kit off the shelf?
Thanks for the pics
Old May 31, 2016 | 10:19 PM
fraser9764's Avatar
fraser9764
Crossover pipe is home made. 22mm copper pipe. Used a pipe bender to put the bend in the air filter end.
Indyrs
Apr 7, 2016 09:53 PM
Turbosimpsons
Apr 3, 2016 08:56 AM
leedsrhinos126
Insurance
Mar 27, 2016 09:02 PM
Acaciastrain360
Mar 15, 2016 04:02 PM
