7J Wheels and Arch Fouling
Hello Folks,
My Escort is slowly nearing completion after a prolonged rebuild (interrupted by arrival of wife and kids). It is wearing aftermarket wheels. I have noticed that the outside edge of the front tyres is getting cut by the wheel arches. Details are:
Wheels: 7J 15H2 AD705 437 - I don't know if any of those later numbers relate to offset but I could find no other numbers.
Tyres: 205/55/15
Car - Lowered by 30mm
The return lip of the wheel arch had been snagged and pulled down slightly. I have since rolled the arches and set the adjustable dampers to their stiffest setting to try to prevent further damage.
Looking on the internet the standard wheels are 6J and the vehicle spec for wheels gives an offset of 35-45.
I need new tyres anyway as the current tyres are perished and cracked.
My question is, should these wheels be suitable for my car (in which case I'll get a new set of tyres for them but in 195/50/15) or do I need to replace them with 6J wheels?
Thanks for looking,
Regards,
Smiler.
Tyres: 205/55/15
Thanks for looking,
Regards,
Smiler.
55 profile is too big so you should really have 50s and as mentioned you need to check your offset as it needs to be right as any lower than 35 and it will start pushing them into the arch more
Thanks for the replies, looks like I need to check the offset. I could not find any other numbers, certainly no ET number which I was looking for. Do any of you know how to physically measure this? (I'm about to google it in the mean time).
The replacement tyres will be 50 profile.
Thanks again,
Smiler.
Thanks again,
Smiler.
Edit: think that was what you meant but I was reading it wrong
I have just been out and taken measurements. The offset comes out at 43mm so should be good.
Just to clarify, the wheels are 7J so 7" wide.
7" % 2 = 3.5" to the centre line.
3.5" = 89mm
Distance from edge of back face of the rim to the hub mating face = 132mm
132mm - 89mm = Offset
Offset = 43mm
I have no signs of inner arch rub so hopefully with a set of 195/50/15 tyres I should be good to go.
Cheers,
Smiler.
3.5" = 89mm
Offset = 43mm
Cheers,
Smiler.
3.5" = 89mm
Offset = 43mm
Cheers,
Smiler.
3.5" = 89mm
Offset = 43mm
Cheers,
Smiler.
Excellent, combined with the narrower tyre giving shaving another 5mm off I should be ok.
Thanks, so just a new set of tyres it is then. Much easier than trying to find a set of wheels within reasonable range.
3.5" = 89mm
Offset = 43mm
Cheers,
Smiler.
3.5" = 89mm
Offset = 43mm
Cheers,
Smiler.
132- 101.6 = 30.4
Ah, that's not so good. I had another look today and they look very close with the wheels straight ahead.
Thanks for that, I'm really not feeling comfortable at the moment with these wheels.
Cheers,
Smiler.
Cheers,
Smiler.
155lee
Mar 7, 2016 06:42 PM
