new reather or rebuild time
Old May 22, 2016 | 09:57 PM
eel-roy-t5r's Avatar
eel-roy-t5r
Default new reather or rebuild time
got a auto specialist breather on the cossie , same type as the bailey ones , breathing from both sides of the block , smallest port on the breather returns to the factory 4x4 sump port thing and the big one vents to atmosphere , now am getting smoke out of the one that vents to atmos .
car is running t34 and 55lbs with a 32psi peak , also heard that the t34 does create a lot of turbo back pressure , could this be the cause or is it rebuild time ???
cheers
B8 GAL
Mar 20, 2016 10:01 PM
Rich654
Mar 13, 2016 10:49 PM
jaimesdna
Mar 12, 2016 05:48 PM
cos elle
Mar 6, 2016 08:31 PM
COLEYST200
Mar 5, 2016 07:05 AM
