What alternator?
The XR3i is back on the road for another summer of fun. But, the alternator is whining plus now and again the alternator sounds like a bag of spanners.
After I killed my original Alternator, I had 2 QX Components branded ones: one was doa; the other died within a day. The next one I had was QH and that one lasted a good few years, but still only about 5k miles.
My question is: what brand alternator are the ones to look for and at what current rating?
Cheers,
Lee
Cheers,
Lee
Lucas on my S2, fitted early 2007 as the factory fit one has knackered...granted it had been sat in a barn for some time. I've only drove the car no more than 8,000 miles since I bought the car in Dec 2006. The alternator is still strong. I run it with roughly 10mm slack on the aux belt.
Thanks lads, I thought Bosch/Lucas may be the answer. I'll have to take a look for one.
You say 10mm slack, 10mm up and down travel on the belt in total? Should add I run a Sierra ribbed belt.
And I'm running EFi with an MFi pump, so 70A+ will be required?
Lee
Lee
i know this is an old thread, but could someone recommend me an alternator.
i want a higher then standard amp if possible
where can i get one from?
i had a look on ebay but im unsure which one would be good or will even fit?
thanks
http://www.ebay.co.uk/itm/New-Altern...UAAOSw4CFY2sfC
thanks
cosworth
May 9, 2016 07:41 PM
