Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Ticking noise
Old May 8, 2016 | 04:23 PM
kerrihbl's Avatar
kerrihbl
Default Ticking noise
Hi I have a Ford Focus estate 55 plate diesel which makes a ticking noise, but it only does it when you are driving it kicks in when you put your foot down so I can't see and listen to where it's coming from unless I drive down the road with someone sat under the bonnet lol it's also sluggish but I think the turbo needs sorting again and isn't connected to the noise as when the turbo was fine the car still made the noise. It's baffling me because it only does it when driving anyone have any ideas on what it could be or where I could start?
Old May 12, 2016 | 12:50 PM
Sp3no's Avatar
Sp3no
High Pressure pump starting to fail as an initial guess but could be a few things such as a tensioner on the aux belt or cam belt or the waterpump.
Is it definitely from the engine and not the transmission
Old May 12, 2016 | 01:11 PM
kerrihbl's Avatar
kerrihbl
Default Thanks for the reply
Thanks for replying, I'm 99.9% sure it's not coming from the transmission, I shall have the Other suggestions checked out
peterblue
Mar 20, 2016 11:11 AM
capri-rs
Mar 14, 2016 01:30 PM
Danielbetty
Mar 14, 2016 10:55 AM
Vesty
Mar 4, 2016 05:43 PM
Rob Winstanley
Ford Focus Range
Mar 2, 2016 06:50 AM
