Pf09 / pf01
Old May 7, 2016 | 03:20 PM
timsrs's Avatar
timsrs
Default Pf09 / pf01
Hi
A mate of mine has a 1991 Sapphire 4X4 and has been having a few issues with idle and hunting on tick over.
We have checked for vac leaks and done a vac test and all is well, so my next thought was the TPS...
When i looked at it i saw that it had a "RED" TPS fitted and thought hey presto found issue as i thought all the PF01 sensors were red.
On removing the sensor is had stamped on it PF09.
Which i thought were all black.
Has anyone else go any PF09's that are red in colour ????
Old May 7, 2016 | 03:41 PM
Sierrasideways's Avatar
Sierrasideways
Mine is red also. PF09 for the L8 ECU.
Philip.
Old May 7, 2016 | 03:45 PM
Sierrasideways
If you zoom and squint you can kind of see the red behind the idle speed control valve
Philip.
Old May 7, 2016 | 08:11 PM
grcossie's Avatar
grcossie
Some pf09 are red others black, have bouth of them
Old May 7, 2016 | 08:22 PM
costina's Avatar
costina
Live long and prosper!!
Early ones red later ones black.
Again i have both.
Old May 7, 2016 | 08:47 PM
timsrs's Avatar
timsrs
many thanks...
I think this is the problem the reading are all over the place.
Can some one confirm what readings should be at closed throttle and throttle fully open.
( PF09 )
Thanks
Old May 7, 2016 | 08:56 PM
steppy's Avatar
steppy
Roughly 0.5 closed throttle to 4.5 open throttle. iirc I set mine to around 0.35 closed throttle maybe even less but can't quite remember it was that long ago
Old May 8, 2016 | 06:34 PM
grcossie's Avatar
grcossie
http://bigturbo.co.uk/
Old May 8, 2016 | 06:43 PM
timsrs's Avatar
timsrs
Many thanks guys will set it up to see if this helps.
BigD.
25
May 12, 2016 08:09 PM
jonmac1
May 9, 2016 09:24 PM
chowfornow
Was It You?
May 2, 2016 06:21 AM
mjonathan24
Apr 24, 2016 07:24 AM
uk-doctor
Apr 19, 2016 02:14 PM
