Forge re-circulation valve
Old Apr 30, 2016 | 11:24 AM
timsrs's Avatar
timsrs
Default Forge re-circulation valve
Hi
I am looking at fitting a Re-circulation valve on my MK1 escort cosworth.
I am at present modifying the pipe-work to suit the re-circulation valve.
I am looking at the FORGE recirc valve.....
Has anyone got one of these units fitted and can vouch for it reliability.
Or recommend an alternative.
many thanks, just before i purchase.
Regards Tim
Old Apr 30, 2016 | 11:32 AM
tony66's Avatar
tony66
Default re-circ
i used [and still have] a bailey motorsprt recirc which replaced the standard location plastic item on my cossie[i dont like vta on them] its anodised black so it looked standard -the plastic ones leak boost too-it gave no issues up to 27psi which is the most i ran on my car
its for sale@Ł50 if intrested give me a shout
Old Apr 30, 2016 | 11:59 AM
timsrs's Avatar
timsrs
Is this a piston type and can it be used on the cold side.
Old Apr 30, 2016 | 12:14 PM
tony66's Avatar
tony66
Default type
its sprung piston type-tbh i wouldnt think it would matter where you used it as long as flow was correct
Mattcortina
May 14, 2016 07:59 PM
Chopshop85
May 2, 2016 05:30 PM
Tinshaw
Apr 29, 2016 08:28 PM
Acaciastrain360
Apr 27, 2016 05:45 PM
grant_xr
Apr 26, 2016 09:07 AM
