which wideband afr set up??
Looking to get a wideband afr gauge but not sure whats the best?
whats everyone else got?
i was looking at this stack unit,
http://www.ebay.co.uk/itm/Stack-Wide...MAAOSwnDxUeapA
I have the stack in my cossie mostly because it matches the other stack gauges.
AEM is nice also.
If you want the most accurate and fastest responding then you need a NTK sensor equipped gauge. Speak to Mark at M.A.Developments.
AEM is nice also.
was just looking at that aim one before you posted! quite like the look of it!
thats why i was leaning towards stack as i have a few stack gauges already!
yea was reading about the ntk stuff, probably a bit to advanced for me really, I'm sure they need calibrating regularly also?
i had an innovate lc in my track car worked fine for me, i also have a KMS wideband controller spare it can work standalone or with the KMS ecu it can display water temp/ boost pressure or air temp when used with the ecu
admanrs
Aug 29, 2016 05:02 AM
