focus st170 timing belt
Old Apr 25, 2016 | 12:57 PM
subhaan's Avatar
subhaan
Default focus st170 timing belt
So a week or 2 back my timing belt went and skipped a good 10 teeth engine cutout and caput. Suspecting valve damage i decided to take the head off strip it and sent it to the machine shop.
Came back with all 8 inlet valves bent and 2 exhaust valves bent. Got all that sorted inc. Shimming lapping etc. But now am reluctant to fit the new head on. Whats the likelyhood of a crack or some damage to the block in this situation bearing in mind the head underwent a full crack test which came back negative?
I have a 2002 focus st170 which is a 2.0L duratec block.
Old Apr 25, 2016 | 01:44 PM
STeve's Avatar
Super Moderator
so the head was naff as I suspected, the block is pretty tough tbh but like any mechanical part I would inspect it top to tail before throwing the head on or its more money your chucking away, had 3 good st170 heads here for £75 too
Old Apr 25, 2016 | 02:35 PM
subhaan's Avatar
subhaan
Aah if only i knew then ended up costing me 140 at the machine shop including crack test
Old Apr 25, 2016 | 04:53 PM
STeve's Avatar
Super Moderator
I break st170s and im only in harrow, whole engine go for 275 tried and tested
Old Apr 25, 2016 | 04:59 PM
big_wasa's Avatar
big_wasa
Should be fine. If it's done any damage it will be to the piston ring lands.
Just stick it back together and hope for the best unless you plan on pulling the engine.
Old Apr 26, 2016 | 06:56 AM
subhaan's Avatar
subhaan
Car is back up and running now thankfully thanks for the info tho mate will defo be giving you a message if i need any other parts
Old Apr 26, 2016 | 07:04 AM
STeve's Avatar
Super Moderator
glad to hear its alive and I have plenty of 170 parts if ever you need any
Old Apr 26, 2016 | 07:47 AM
subhaan's Avatar
subhaan
Do you have the exhaust manifold heatshield by any chance 😄
big_wasa
12
Sep 6, 2016 08:56 PM
disco-stu
Mar 16, 2016 07:35 AM
Ford Focus ST Parts for Sale
Mar 1, 2016 07:03 PM
Will Pedley Racing
Feb 24, 2016 05:22 PM
