I wan't to take off the front bellhousing part of the gearbox. Does the driveshaft guide sleeve have to come off before being able to remove bellhousing or can it be done without removing it as the guide sleeve looks to be screwed into the bellhousing itself. I'm asking this because taking off the guide sleeve requires a special tool which I don't have. Anyone know?
not done it myself, but i remember a friend of mine cutting a socket up and welding a tube in the middle of it for this purpose, so i'd assume it needs to come off.
