Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
Intermittent no crank no start. Faulty relay?
Old Apr 12, 2016 | 06:51 AM
James Brunt's Avatar
James Brunt
Question Intermittent no crank no start. Faulty relay?
Hi there,
My car has developed an intermittent no crank no start fault where when I try and start the car I get all lights but nothing happens when I hold the key to the start position. The car will start when I either try a few more times or if I hold the key in the start position for about 5 or so seconds.
I think this would indicate a faulty relay as the car cranks and starts first time normally and this problem is intermittent.
I have looked in the passenger glove box at the relays and the start inhibit relay has the following numbers:
2S7T 14B192 AA and V23136 B1 X66.
A quick Google and it seems that it may be the same relay as 5M5T 14B192CA but I can't be certain.
I can only seem to find used relays on eBay and I would probably rather get a new relay but I don't want to go to ford as they will probably charge 3X the normal price. Does anyone know where I can get a new relay from?
Thanks
James
2002 Ford Focus MK1 TDCI Ghia X
Old Apr 12, 2016 | 05:14 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Can you turn on your head lights? and if so are they bright or dull. This is just to determine the condition of the battery. It's a process of elimination really.
Old Apr 12, 2016 | 11:00 PM
James Brunt
The headlights are fine and the battery is in good condition as I tested it about a month ago. When the engine does turn over it starts up fine and there are no battery lights on. Voltage is good too.
Old Apr 12, 2016 | 11:50 PM
botters's Avatar
botters
competant bodger
possible that the starter solenoid is on its way out too
Old May 27, 2016 | 07:47 PM
Jamieb16v's Avatar
Jamieb16v
I reckon starter relay. Or dodgy solenoid
peterblue
Mar 20, 2016 11:11 AM
thomasbiglad
Escort Range
Mar 19, 2016 12:08 AM
marky_g
Mar 17, 2016 09:35 PM
Danielbetty
Mar 14, 2016 10:55 AM
marky_g
Mar 13, 2016 09:16 AM
