long stud kit help!!!!
Old Apr 11, 2016 | 09:27 AM
lee954's Avatar
lee954
Default long stud kit help!!!!
hi everyone just bought a saff cosworth with head gasket gone but cannot get head off due to being fitted with long stud kit but the holes in the head have not been machined out so cant get a socket in th the nuts! i have had two sockets turned down on a lathe but both have broken when trying to undo the nuts?? anyone got any ideas please???? thanks
Old Apr 11, 2016 | 10:32 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
When I took my head off my engine I borrowed a ground down socket off a mate. There was very little room
Old Apr 11, 2016 | 12:28 PM
costina's Avatar
costina
Live long and prosper!!
What block? Hope its not arp kit.
Could try turning down a inpact socket.
Old Apr 11, 2016 | 05:10 PM
Ridgey's Avatar
Ridgey
I've used a turned down socket without issues.
You really need to have the socket turned down so it only just fits in, keep as much meat on it as possible.
Old Apr 11, 2016 | 05:38 PM
lee954's Avatar
lee954
it's a 200 block and i have measured the holes at about 23mm. not sure what kit it is as was already on when i bought the car. i looked on some other posts here and most are saying 18mm nut sure my one is 19mm do they do different sizes?
Old Apr 11, 2016 | 06:23 PM
jamie956's Avatar
jamie956
My mates just been through this the newer long stud kits are now using a bigger nut (19mm i think) and you really need to machine the head out, only way to get off is to keep trying with the machined down sockets.
Try machining down a multi point socket not a 6 side.
Old Apr 12, 2016 | 08:18 AM
lee954's Avatar
lee954
ok thanks! looks like it is going to be a case of just keep trying just hope they will come loose otherwise not sure what i can do!!!
Old Apr 20, 2016 | 06:33 PM
mattman1234's Avatar
mattman1234
same here,ground down a socket
Old May 12, 2016 | 04:41 PM
20/20 vision's Avatar
20/20 vision
From: it's not where you are, it's where you've been and where you hope to be
julian godfrey sells smaller nuts which fit without any socket machining
Old May 12, 2016 | 05:04 PM
Caddyshack's Avatar
Caddyshack
Lol, at least we know what the previous owner should have fitted.
Good to know for putting it back together though
wayne1001
Jul 9, 2016 01:19 PM
turbotrev
Apr 15, 2016 07:02 PM
steppy
Apr 10, 2016 03:55 PM
mondeomark
Apr 9, 2016 07:50 PM
jamie956
Apr 8, 2016 09:45 PM
