brodie britain racing
Old Apr 6, 2016 | 04:17 AM
polle90's Avatar
polle90
Default brodie britain racing
Hello, i can buy an ecu from brodie britain racing. Is that any good?
Are all type of rs turbo ecu interchangebale?
Regards
Old Apr 7, 2016 | 08:33 PM
Nosmonkey's Avatar
Nosmonkey
Early RST ECUs (S1, early S2) aren't equipped with knock sensors and are interchangable. Later ones are equipped with a knock sensor and are not interchangeable with the early type.
Blue-Red-Blue = S1
Blue-Red-White = Early S2
Blue-Red-Black = S2 equipped with knock sensor, green sensor mounted on RH of inlet is the knock sensor
Hearts & Diamonds = 90 Spec S2s
As for BBR, I was going to pick one up some time ago but was told by a friend they weren't up to much scratch. Bear in mind that you will require a set up as simply bolting on a chipped ECU to an otherwise standard car could lead to disaster. Personally I wouldn't bother getting a 2nd hand unit and would look into getting a proper set up from a reputable tuner.
Old Apr 8, 2016 | 05:59 AM
polle90's Avatar
polle90
I am aware for the set up. I assume that the bbr chip does the same thing as the other chips, removing
the boost limiter are am I wrong?
Regards
Old Apr 8, 2016 | 06:09 PM
Nosmonkey's Avatar
Nosmonkey
Think it was 1 bar (14.7psi) limit, was one for sale new a year back and I recall that having a 1 bar cut.
Kam B
29
May 16, 2016 08:37 AM
RsS2daz
May 3, 2016 05:19 AM
tlr_rst
Apr 4, 2016 06:52 AM
griffo69
Apr 3, 2016 07:01 PM
paceo
Apr 3, 2016 02:48 PM
