Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Ford Fiesta 1.4 MK6 - 53 Plate - Engine Mangement
Old Apr 3, 2016 | 03:05 PM
scott-UK's Avatar
scott-UK
Smile Ford Fiesta 1.4 MK6 - 53 Plate - Engine Mangement
Hi, I'm having problems with my Fiesta with a lack of power and the engine management light turning on and off!!
I took my car to a friend with a diagnostics kit and it showed the following codes:
HO2S-11 (Heated Exhaust Oxygen Sensor Right Upstream) Circuit Slow Response
System Too Lean Bank 1
HO2S-11 (Heated Exhaust Oxygen Sensor Right Upstream) Circuit Malfunction
Invalid fuel tank level message from instrument cluster
Knock sensor 1 circuit malfunction
I changed the Oxygen sensor back in 2014 - Could this have gone already?
I would be extremely grateful for any advice anyone may have for me!!
Old Apr 4, 2016 | 11:37 AM
oldford's Avatar
oldford
I would be looking at the mixture the engine gets. It seems to be lean.
OR you have a leak in the first part of the exhaust near the oxygen sensor.
What's your fuel consumption doing? Same, higher, lower?
Old Apr 5, 2016 | 09:24 AM
scott-UK's Avatar
scott-UK
OK thanks, may sound slightly stupid but I'm new to this - How would I test if there's a leak?
I would say it's about the same.
Old Apr 5, 2016 | 03:07 PM
oldford's Avatar
oldford
Start the engine, block the end of the exhaust and without a leak the engine should stall.
With a leak the engine keeps running and you should be able to hear where it leaks.
But with the fuel consumption being about the same, I would say the cause is something different. Maybe a leak somewhere around the inlet manifold or a defective sensor.
Can your friend read live data? Then check the "Fuel Trims".
They should be close to 0%.
Old Apr 25, 2016 | 07:20 PM
vrum-tss's Avatar
vrum-tss
noob
what brand of sensor did you use? i wouldnt recommend anything other than a bosch one. if its a cheap'n may well have gone again,
other possible causes, expended or blocked CAT (do you notice any bad smells coming from the car?) , possible wiring malfunction
did he clear the codes and retest? or just a single test, i would clear and retest as it eliminates previous faults that could have been cured and still recorded.
my neighbours fiesta had a lack of power issue, turned out to be blocked CAT causing backpressure in the exhaust system and making it run bad , check all the basics, plugs fuel filter etc, does it misfire? blocked cat could explain the lambda sensor reading bad
Old Jun 12, 2016 | 08:05 PM
scott-UK's Avatar
scott-UK
Smile Faulty Lambda Sensor!!
Hi,
Problem was the Lambda sensor! Orignal sensor I used was HAAS - Must have been faulty!
I've now replaced with a NGK sensor and its worked a dream!!
Thank you both for your replies, much appreciated.
cutch
11
Feb 22, 2016 07:43 PM
Monster36
Ford Fiesta
Feb 15, 2016 11:31 AM
Tommy777
Feb 10, 2016 09:46 PM
No-nonsensical
Ford Mondeo Including ST
Feb 8, 2016 05:17 PM
KAnne
Ford KA
Jan 23, 2016 03:33 PM
