Big spec parts Zetec turbo lots
Old Apr 2, 2016 | 12:48 PM
RsS2daz's Avatar
RsS2daz
Default Big spec parts Zetec turbo lots
massive spec escort rs turbos being broken
Cosworth management conversion full.
L6 ecu
Full braided loom
Efi adaptor plate and
Inlet modified for cossie tb
Cossie tb with tps and iscv and okc throttle cable bracket
Map sensor weber
Cam sensor and pickup disc and bracket
Crank sensor
Sierra 1.8 bottom trigger wheel
Blue or yellow injectors
All vacuum pipes quick release okc
Everything is there to convert
£1200
1.6 cvh Rs turbo engine ported mfi head vernier pulley. Good working condition £400
Series 1 roll bar kit painted gold £250
Series 2 gearbox with lsd £200
Compbrake adjustable top mounts new £80
Series 2 shell good condition in white one repair needed to sill all painted white underside £1000
Standard t3 turbo unknown condition £100
88 spec full interior good condition rear seats have a hold £250
Spec r coolant tank £80
Cossie 2wd rear disc conversion with billet brackets £300
300mm brake kit £175
Full Roose boost and coolant / auxiliary hoses in blue £200
90 spec rear spoiler £75
Gaz Coilovers and springs could do with rebuild £150
Mint Rs turbo shell in Ferrari grey with full Perspex windows with focus Rs conversion mounts etc all rolling ready to go £3000
Sparco roll cage new never used only fitted £350
Garrett T4 turbo .63 exhaust never used since being built £800
zetec turbo Crazycage over the gearbox manifold with t4 flange external
waste gate take off £550
zetec turbo crazycage custom plenum new £550
custom 3" exhaust system fully tig welded this is the absoloute bollocks of an exhaust system comes with 2.5" outward rolled tip new never used cost near enough a £1000 to be made £650
compbrake pedal box gets ride of servo new £130
tial 44mm external wastegate polished new £300
opi zetec turbo dry sump kit new £1000
zetec turbo 2.0 fully forged engine , wossner forged pistons pec rods, crazycage ported head, devil development cams and springs Vernier pulleys all built up ready to go all new £2500
focus rs gearbox quaife atb diff £700 used
custom crazy cage driveshafts never used since being made just mocked up £200 all built up ready to go
focus rs brembo 4 pot front brake kit and new discs and pads brackets all to suit escort rs turbo £350
rear disc conversion cossie 2wd calipers and discs everything there £300
Escort rs turbo roose water and auxillary hoses in black new never used in bag still £200
auto specialists alloy header tank copy of bailey ones new in black £80
cobra Monaco seats new £300
trs 4 point harnesses new in box £250
airtec rad used £100
big intercooler and fan setup not sure on make in black good condition used £100
6 point bolt in cage sparco brand £300
ford racing boost £120
ford racing oil pressure gague £120
loads more please give us a ring or message on 07805451065 I can send pics etc cheers daryl
Old Apr 4, 2016 | 10:24 PM
slammedorion's Avatar
slammedorion
Pm'd
Old Apr 13, 2016 | 03:45 PM
jimmk1's Avatar
jimmk1
pm'd mate
Old Apr 15, 2016 | 08:48 PM
sandyRS16i's Avatar
sandyRS16i
PM sent - Re radiator
Old Apr 23, 2016 | 12:02 AM
IanC's Avatar
IanC
Any pics of the crazy cage inlet?
Old Apr 23, 2016 | 10:49 PM
ford87's Avatar
ford87
And
Still for sale?
Old Apr 25, 2016 | 04:18 AM
RsS2daz's Avatar
RsS2daz
And
Still for sale?
Hi mate yes still here give us a ring or message on 07805451065 cheers
RsS2daz's Avatar
RsS2daz
Sold sorry
Old Apr 25, 2016 | 05:57 AM
mtbeni's Avatar
mtbeni
PM sent.
Old May 2, 2016 | 09:53 PM
ford87's Avatar
ford87
Do you have photo of the parts? Will the driveshaft fitt in a escort mk4 whit zetec engine?
Old May 3, 2016 | 05:19 AM
RsS2daz's Avatar
RsS2daz
Hi yes will fit Zetec turbo mate...
Give us a a message on 07805451065 and il send some across
dal3door
15
Apr 24, 2022 07:31 PM
jason3249
20
Feb 2, 2016 08:18 PM
CrOwSoN15
Jan 22, 2016 05:22 PM
bc771
Jan 21, 2016 11:50 AM
cgray0291
Escort Range
Jan 20, 2016 06:19 PM
