CVH RS Turbo High Specification Parts for sale
Old Mar 27, 2016 | 07:49 PM
admanrs's Avatar
admanrs
Default CVH RS Turbo High Specification Parts for sale
Will be selling high specification parts which were going to form part of my Fiesta RS Turbo project which I am reluctantly selling. The specification was designed to be very high powered CVH so a few of these parts are fairly special. Will be adding more gradually as I go through my stock but to start please see below.
Helix paddle clutch kit: Ford CVH 220mm
Includes clutch cover, 6 paddle clutch plate and clutch release bearing.
Brand new unused (Sold)
Turbosport Ford fiesta RS Turbo Flywheel Billet Steel light weight flywheel 3.8kg (Timing holes on the back side for the crank sensor)
Brand new unused. (Sold)
Turbosport Ford CVH Vernier Pulley adjustable 12 degrees each way
Tubular manifold made from 2mm stainless steel, flange was removed therefore new t3 flange will need to be welded onto the manifold
Added 28/03/2016
Garrett GT2876R
•T3 turbine inlet flange
•5 bolt discharge ford style
•Turbine housing .64
•For external wastgate
Brand new unused £600
Tial 38mm external wastegate
Brand new unused (sold)
CVH EFI RS Turbo Inlet
Modified to accept -6AN fuel lines both feed and return. Fitted with Bosch 803 injectors, Fuelab fuel regulator please message for more details
Injectors and fuel regulator as new £275 or £140 without injectors (sold)
Cometic multi-shim head gasket CVH
ARP head stud kit CVH
Ford IB5 Gearbox fits CVH engine
Fitted with Quaife differential rebuilt with new bearings and synchromesh and covered less than 500 miles. £600
Three CVH EFI RS Turbo heads
1 x Brand new bare CVH EFI RS Turbo Head (£250)
1 x Cylinder head modified to accept 43mm inlet valves standard exhaust valves good condition stripped back to bare cylinder head (£180)
1 x Cylinder head modified by Dave at Puma Racing modified for 45mm inlet valve large amount of work has gone into this head. Which can be seen unfortunately there is some wear on the journals for the cam shaft I was going to get these machined and a custom cam shaft made. (Offers)
Attached Thumbnails CVH RS Turbo High Specification Parts for sale-img_2736.jpg   CVH RS Turbo High Specification Parts for sale-img_2737.jpg   CVH RS Turbo High Specification Parts for sale-img_2741.jpg   CVH RS Turbo High Specification Parts for sale-img_2723.jpg   CVH RS Turbo High Specification Parts for sale-img_2724.jpg
CVH RS Turbo High Specification Parts for sale-img_2727.jpg   CVH RS Turbo High Specification Parts for sale-img_2734.jpg   CVH RS Turbo High Specification Parts for sale-img_2735.jpg   CVH RS Turbo High Specification Parts for sale-img_2731.jpg   CVH RS Turbo High Specification Parts for sale-img_2718.jpg
CVH RS Turbo High Specification Parts for sale-img_2714.jpg   CVH RS Turbo High Specification Parts for sale-img_2715.jpg   CVH RS Turbo High Specification Parts for sale-img_2720.jpg   CVH RS Turbo High Specification Parts for sale-img_0354.jpg   CVH RS Turbo High Specification Parts for sale-img_0355.jpg
CVH RS Turbo High Specification Parts for sale-img_0264.jpg   CVH RS Turbo High Specification Parts for sale-img_0269.jpg   CVH RS Turbo High Specification Parts for sale-img_0266.jpg   CVH RS Turbo High Specification Parts for sale-img_0268.jpg   CVH RS Turbo High Specification Parts for sale-img_0337.jpg
CVH RS Turbo High Specification Parts for sale-img_0338.jpg   CVH RS Turbo High Specification Parts for sale-img_0339.jpg   CVH RS Turbo High Specification Parts for sale-img_0141.jpg   CVH RS Turbo High Specification Parts for sale-img_0143.jpg   CVH RS Turbo High Specification Parts for sale-img_0146.jpg
CVH RS Turbo High Specification Parts for sale-img_0155.jpg   CVH RS Turbo High Specification Parts for sale-img_0157.jpg   CVH RS Turbo High Specification Parts for sale-img_0158.jpg   CVH RS Turbo High Specification Parts for sale-img_0149.jpg   CVH RS Turbo High Specification Parts for sale-img_0150.jpg
CVH RS Turbo High Specification Parts for sale-img_0148.jpg   CVH RS Turbo High Specification Parts for sale-img_0174.jpg
Old Mar 27, 2016 | 11:03 PM
boeb's Avatar
boeb
Hi m8 wots price on tubular and fly wheel posted ..central scotland
Old Apr 1, 2016 | 11:51 AM
Pete frst's Avatar
Pete frst
Is the turbo still for sale?
Old Apr 1, 2016 | 04:41 PM
admanrs's Avatar
admanrs
Yes turbo is still for sale
Old Apr 17, 2016 | 11:14 AM
214_si's Avatar
214_si
You have pm
Old Jun 13, 2016 | 07:17 PM
admanrs's Avatar
admanrs
Turbo reduced to £600
Old Jun 30, 2016 | 02:20 PM
stevo325's Avatar
stevo325
Hi mate, you wouldn't happen to have a standard RS turbo piston about would you?
Old Jul 13, 2016 | 10:38 AM
cge's Avatar
cge
Is that a front or rear starter ib5 mate? Do you know what it was originally out of or what gearset is in it?
Chris
Old Jul 24, 2016 | 06:13 PM
goldenbrown's Avatar
goldenbrown
£450 for the gearbox?
Old Aug 15, 2016 | 10:39 AM
Phil_rs1800's Avatar
Phil_rs1800
Hello mate, Interested in the Brand new head. Can you give me some more details with where this came from etc?
Old Mar 13, 2017 | 12:06 PM
jhoward's Avatar
jhoward
hi do you still have the efi manifold
Old Mar 20, 2017 | 12:52 AM
Rich87's Avatar
Rich87
Probably not as this is just over a year old mate
Old Mar 20, 2017 | 07:21 PM
crash&burn's Avatar
crash&burn
I have a efi manifold you can have for £50
raymond dobbie
Apr 4, 2016 09:31 AM
cutch
11
Feb 22, 2016 07:43 PM
155lee
Feb 9, 2016 01:01 PM
boost monster
Feb 4, 2016 10:08 PM
harvcore
PassionFord Swap Shop.
Jan 20, 2016 01:56 PM
