Rev counter
Old Mar 24, 2016 | 06:10 PM
L33_srd's Avatar
L33_srd
Default Rev counter
My rev counter only seems to read up to 3k rpm , are their common issues with them ? It is 2.1zvh on gotech, coil pack ect where does it get its feed from ? Any input would be appreciated cheers
Old Mar 24, 2016 | 09:08 PM
studabear's Avatar
studabear
You could try fitting the rev counter from a efi escort/orion.
Old Mar 27, 2016 | 07:30 AM
mentalasanything's Avatar
mentalasanything
In an EFi setup the Rev counter needs its feed combined from both coils (not one coil as it does with a dizzy) hence half the revs.
You can either try and find an EFi rev counter as suggested by studabear or you can add the following circuit:
It's a very simple cheap circuit made of 3 diodes. I added this to mine right down near the EDIS and attached it to the original green rev counter wire with a bullet connector in the original location.
Lee
Edited as it read badly...
Old Apr 1, 2016 | 03:28 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Does it read correctly up to 3k?
Old Apr 4, 2016 | 03:42 PM
L33_srd's Avatar
L33_srd
Cheers guys , seems to read correct to about 2800 rpm then just sticks but i noticed on the motorway the needle seems bounce up and down slightly, im going to have a look into this tomorrow
Marc sierra
49
Dec 24, 2021 12:12 PM
jockey-ka
Ford KA
Jun 24, 2016 01:21 PM
fordsteve77
Mar 15, 2016 01:25 PM
willos90
Ford Mondeo Including ST
Feb 26, 2016 07:52 AM
